I need my 1952 Ford 8N to start... please help!!
   / I need my 1952 Ford 8N to start... please help!! #1
macecase
Bronze Member
Princeton, KS
1965 John Deere 3020 Diesel and 1975 John Deere 4630 Diesel
I really need this tractor to work... It worked great for a while after I bought it but now doesn't start. I am at the point of just buying another tractor because I need a working one.... But, I am attached to the Ford 8Ns and don't want to do so. It makes better sense to fix this one.
To me, it seems the starter is really slow.... But, it is 6V and I am used to 12V sounds.... Anyway, I have a brand new battery in it with no changes. I am all ears and will post back responses to all suggestions, requests for measurements, etc....
Thank you!
   / I need my 1952 Ford 8N to start... please help!! #2
Always check spark first on a gasser when it dont start, if it is spark try it with starter fluid if I bangs on that, check fuel, post back
   / I need my 1952 Ford 8N to start... please help!! #3
IT dont sound right to me. Only sounds like one or two cylinders is building compression. Get a compression tester and check compression of each cylinder. I am betting you are down a few cylinders. A head gasket or a valve stuck open are the likely two.
   / I need my 1952 Ford 8N to start... please help!! #4
Yep, guessing stuck or burned valve. Shouldn't hear that noise in the air cleaner.
   / I need my 1952 Ford 8N to start... please help!! #5
I didnt notice much noise in the air cleaner. But tehn again, computer speakers arent the greatest. I did notice it missing some compression cycles though...
   / I need my 1952 Ford 8N to start... please help!! #6
thumb over plug holes and valve side covers off will tell a tale.
I made a trip to harbor freight and purchased a compression test kit. Cylinder 1 & 2 have ZERO compression. 3 & 4 register about 65 pounds.
Now, what should I do?
   / I need my 1952 Ford 8N to start... please help!! #8
Pull the cylinder head off. Hopefully you just have a blown gasket. Also check and see if you have antifreeze in the engine oil. If you do, you need to do an oil change.
Again, could also be a valve stuck, which you would see by popping the head off and cranking the motor over by hand.
Worst case would be busted pistons, broke crank, cracked block, etc.
Pulling the head comes first. But the 65psi concerns me on the other two holes as well...
   / I need my 1952 Ford 8N to start... please help!! #9
exactly what i mentioned.
pull valve side covers... i bet for find the intakes for 1 & 2 stuck open.
is it possible to pull the head without having to take the hood off? I would imagine no, but I thought I would ask.
UNUSED FUTURE MINI EXCAVATOR RAKE (A51244)
UNUSED FUTURE MINI...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
CATERPILLAR 819 PADFOOT LANDFILL COMPACTOR (A51242)
CATERPILLAR 819...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
