I need to cut a kitchen counter top.
   / I need to cut a kitchen counter top. #11
Cut form the back. Plywood blade. Masking tape on the good side. Start cutting from the front edge toward the back, then over the lip for the back splash. Make sure someone holds the cut edge. Very easy to do and looks nice.
Ron
   / I need to cut a kitchen counter top. #12
I'm curious how you would use a router on a laminate counter top? The ones I've done are pre-formed with a backsplash from Home Depot and Lowes.
I can't figure out how you would cut the backsplash with a router?
Eddie
   / I need to cut a kitchen counter top. #13
Eddie
Mornin Eddie,
It would be two seperate setups with a straightedge. You could also use a downward spiral bit to cut through the formica so as not to lift the formica, instead your pushing in the downward direction. The back splash would have to be cut from the backside obviously.
   / I need to cut a kitchen counter top. #14
EddieWalker said:
The straight edge is the key. Don't cut until you have it positioned exactly right, and then make your first pass very, very shallow. This way you can double check your measurements before you cut all the way through it.
Eddie
And most important is to make certain your final (or only) cut JUST barely clears (protrudes) through the material.
Bob
378747 (A51572)
378747 (A51572)
3000 GAL  SELF CONTAINED FUEL SKID (A52472)
3000 GAL SELF...
CENTRAL PNEUMATIC  GAS 135 PSI (A52472)
CENTRAL PNEUMATIC...
2001 Ford F150 (A50121)
2001 Ford F150...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
