Wow, that's worse than hydraulic fluid in my beer, which has been know to happen,
Were you hoping the anti-foam properties of Hyd fluid would work on the beer ?
Drink safe.
Rgds, D.
Yeah, I once put maple syrup in my coffee, thinking it was rum.Things happen. I once put rum in my coffee thinking it was sugar. Go figure.:confused3:
If you cannot easily drain the line just crack it at the injectors. After changing everything you can PROBABLY just leave the injectors cracked and pump (crank the engine) until good diesel squirts out. It might be worthwhile to make an effort to buy some off-road diesel so you can see the red coming out.
Change oil and filter also.
Why change the oil and filter?
No No No please Do not crank the engine, pumping more gas through the fuel injection pump will cause more drama if it hasn'r already done so (the fuel injection pump relies on Diesel too for lubrication ) - instead remove (later replace) the fuel filter & drain through the lines, & as others have detailed crack the fuel injectors/lines & manual bleed the system to remove all the gas then refill with diesel (+lubricant even if it just some added engine oil) bleed throught he lines then prime & try to start - with any luck you haven't done any damage to date.
