ID hydraulic line; TC40D
   / ID hydraulic line; TC40D #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
My TC40D has a leak in a rubber "T" on what appears to be hydraulic low pressure return lines. It has a crack in the "T". I looked at Messicks, but could not find a diagram that showed it.
Looking to replace that, but trying to identify it. I only have 100 hours on the hydro fluid, but guessing it will have to be drained to fix this. So planning on filter and fluid too.
This is one of those odd hoses, that will probably be impossible to find in 10 years...
   / ID hydraulic line; TC40D #2
Try a plumbing dist. look at copper tees or even maybe pvc. There is rubber couplers you can get also.
   / ID hydraulic line; TC40D #3
Parts book shows SBA398120870 connector for TC40D with HST?
That is it; awesome! Thank you! Looks like easily available part.
Got the part. Anyone know, if changing that hose will require draining the whole hydro system?
Tore it apart last night. Drained fluid thru the broken rubber hose. Looks like about 6-7 gallons. So will just replace the fluid and filters.
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A56858)
2017 Autocar...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2010 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2010 Chevrolet...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
