ID this tree
   / ID this tree #1
sensabmc
Vancleave, MS
Mahindra Max28XL
I think it's a cypress. I live in the gulf coast region of Mississippi.
The logs weigh a ton. I can pick up the 4 and 5 foot long sections with my loader but the 10 foot section won't even move.
20-24" in diameter.
Here are the pics. I cut a sample block so you can see the inside. The inside is what has me stumped.
   / ID this tree #2
Looks like cypress. Was it under water?
If it's cypress it will smell great.
   / ID this tree
Came from about 30 feet where it lays so no water. It smells like gasoline to me.
   / ID this tree #4
Hard to tell. Not much bark left on the trunk. Is the wood spongy? If the tree has been dead for a long time, it could be a fungus inside the wood.
   / ID this tree #5
Looks like the wood is either spalted, or has begun to decompose. Spalting is the early stage of decomposition that gives the wood interesting patterns, but the wood is still usable. Once it gets past that point, it's not much good.
When dried and cured, Cypress looks very much like other white softwoods. When fresh cut, it will have a slightly darker appearance.
Here's a milled cypress beam, but this was standing dead wood so it was basically dried/cured in place:
Here's a piece of spalted beech for conversational purposes:
   / ID this tree #6
I have seen at least one upscale home in this area trimmed on the outside with something he called "Pecky Cypress". It had a lot of holes and grooves, supposedly caused by fungus. Could this be what we have here? Cypress is not common around here.
   / ID this tree #7
Well, I know its not any kind of tree from around this neck of the woods.
Toro Zero Turn (A50324)
Toro Zero Turn...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
Lincoln Electric 225 Ranger Welder Generator (A52377)
Lincoln Electric...
