Identification/Serial Number Tags
   / Identification/Serial Number Tags #1
MasseyWV
Veteran Member
While I'm working to restore my Massey 135 tractor, I'd also like to replace the engine identification and serial number tags with new ones.
The serial number tag is located on the side of the battery support box and was easy to remove because it was attached with 4 small phillips head screws. I've located a appropriate new replacement serial number tag that matches the old one, but I need to find a place that can copy the serial number from the old tag and engrave it into the new one.
The engine identification tag is attached to the engine block with 4 rivets but I'm not certain how to remove them. I'll have to look at it again to be certain, but I believe the engine identification tag also has numbers which will need to be copied from the old one and engraved into the new one.
Does anyone know how to remove the engine identification tag rivets and/or get identification tag numbers engraved?
   / Identification/Serial Number Tags #2
G'day I have been able to get a small screwdriver under the head of those rivets and have pried them up, but as to a replacement tag sorry no idea where you would go for that
Jon
Well, it looks like I spoke too soon about having located replacement identification tags/data plates. The source I mentioned only has the data plate for the Continental Z-134 engine, and no longer has the serial number plate in stock. This may be more difficult than I had originally thought.
If anyone knows a source for reproduction serial number and engine identification data plates for a 1966 Massey 135 tractor with a Continental Z-145 gasoline 4 cylinder engine, please let me know.
Serial Plate:
Engine Plate:
Kubota ZD331 Diesel Zero Turn Mower (A50860)
Kubota ZD331...
UNUSED Black Metal Roof Panels (A50860)
UNUSED Black Metal...
2018 Ford F-550 4x4 Summit 4416 4,000LB Crane Mechanics Truck (A48081)
2018 Ford F-550...
2018 Bobcat E32i Mini Excavator (A49346)
2018 Bobcat E32i...
2012 John Deere 468 Round Baler (A50490)
2012 John Deere...
Questions??? (A50490)
