If Deere made the 318 would you buy?
   / If Deere made the 318 would you buy? #31
I'm a little late joining this discussion, but I have an '89 318 with the 50 inch deck and 54 inch front blade that I bought new...it now has about 1400 hours on it and got worked very hard here. I would buy a new one tomorrow if they were still in production, but I needed something larger so that's why I now own a 4210.
The trouble spots in my JD were mainly electrical, I had to replace the ignition switch, pto switch, neutral safety switch, etc. and now it needs some more electrical work as it will run for a minute and then the juice shuts off. As for oil leaks, mine was very oil tight but because I changed the oil so frequently the brass drain plug finally snapped off, when I rebuild the engine I will replace that. Another thing you could look for on a used 318 is the power steering cylinder, they cost about $200 to replace as they are not repairable.
Something I loved about my 318 was the durability, they engineered it strong....the rear axle is HUGE, I devoted many hours with mine doing full throttle work moving large rocks with the front blade, or using the rear hitch point to pull heavy loads. Other than batteries, electrical switches, and tires I never had to replace any parts on mine outside of filters.
In my area a 318 with a 50 inch deck and 800 hours sells for about $2600...I have thought about buying another because I think they are the best machine Deere ever made for the money.
This 318 does not have the rear pto. I don't think I should get this one as the price is a little high for the rough shape. I did manage to find a 1985 316 for $1600 so it is 100 bucks more than the other one at my dealer but it appears to be in better shape. It will need less work. I just need to head to the other dealer and see it in person. I will get one sooner or later though! I am having a very hard time finding a semi decent one around here.
   / If Deere made the 318 would you buy? #33
"I did manage to find a 1985 316 for $1600"
Nick,
Do you mean "318" or is it a 316? There is quite a difference in the two tractors.
Ken /forums/images/graemlins/smile.gif
No it is a 316. I know I would only have one SCV instead of 2 and the 16 horse Onan but I don't care. It still drives the same as the 318 I have driven many of each at the old JD store. I also will not get the power steering which I kind of thought would be nice to have but have gone without for my whole life anyway. More to break I guess. I hate to buy the one at work being as high priced as it is when I can get a little different tractor for the same price in much better shape. I'll have to look at it this weekend.
   / If Deere made the 318 would you buy? #35
I own two 316s (one old Kohler powered and one newer Onan powered) and the power steering is something I can live without, but the extra set of hydraulics up front for the front blade is a BIG bonus! To be able to power angle the blade on one of mine and not the other makes a big difference. Other than that, the Onan 316 and the 318 are essentially identical as far as attachments and capabilities. They are both good tractors and are better than most new ones out there.
   / If Deere made the 318 would you buy? #36
I had a 1984 318, with only 190 hours on it when i bought it. It was a great tractor, puts the new models to shame I think. The 318 is a super tough tractor, with great hydraulics, etc. The onan engines they used are pretty much bullet proof, and you can expect them to run over 3000 hours if you take care of them. The attachements they had are great. You can still find a lot of stuff for 318s, etc. My dealer has 3 318s in stock.
   / If Deere made the 318 would you buy? #37
Hi, I was wondering if someone would comment on the JD-400 vs the 318. I know it was the first 400-series model and I like it's looks and size, and of course they're old enough to become actually "affordable" for me. Is the 400 not considered as reliable or desireable as the 318? Any other downside in your opinions, like more plastic body work or lighter tranny or ?? I think it has a foot operated hydro control, vs the dash mounted lever on the 318? I think I might prefer the foot pedal(?) Thanks in advance.
Bill in CO
   / If Deere made the 318 would you buy? #38
I think the original 400 was actually the heaviest GT Deere made *maybe* up to the X-series. When the 316 (new version), 318, 420, 430 series came out in 1984 I think the newer 400 level machines of that group (good as they are) were actually la little ighter duty.
One issue with the older 140 and 400 units - I understand parts are starting to get a bit tough to come by, the 318/420 era machines (made up through 1992) are still pretty well supported (that's not to say *everything* is still available).
If you haven't already, take a look at this site...
Weekend Freedom Machines
   / If Deere made the 318 would you buy? #39
Wow, thanks fir the info and the link Tim. I had no idea that production of the original 400 began way back in '75 and went for 8 years before the introduction of the 420. I do like the looks of that beast, though. But I suppose one that old in good condition would be hard to find.
Bill
   / If Deere made the 318 would you buy? #40
I don't think I have ever seen an actual 400...my 1988 JD L&G brochure has an illustration of a 1979 400 on the inside back cover along with a trade in value....it says a '79 400 listed for $4399 new, and in 1988 it had a trade in value of an average of $2,287...52% of list.
Tim...thanks for the link... /forums/images/graemlins/smile.gif
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2018 INTERNATIONAL LT SLEEPER (A54607)
2018 INTERNATIONAL...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
