If you struggle to see the hydraulic oil level...
   / If you struggle to see the hydraulic oil level... #1
Teachu2
Platinum Member
Keene, CA
Kioti DS3510 Husqvarna GT48DXLS
I couldn't check mine without readers and a flashlight - couldn't see the fluid well enough. Easy solution - Go to a Deere dealer and get part#MT3668. Should be ~$6. It is a bottle of red dye for hydraulic oil, so you can easily read the sight glass and/or dipstick. Pour it in, run a couple of minutes, and never strain trying to see it again.
If you don't want to go to a dealer, you can get it shipped to you for $13. The local Deere parts people told me they could order it, $12, take two weeks to get. I asked at the lawn and garden parts counter at the same dealer (20' away in the same room!), he got it in two days for $6.....
   / If you struggle to see the hydraulic oil level... #2
I usually just put the stick on my glove or pants leg.
But it's been discussed on TBN before for years. Used to be $4.25.
   / If you struggle to see the hydraulic oil level... #3
Or add a liter of ATF.............Mike
   / If you struggle to see the hydraulic oil level... #4
I pull the dipstick, wipe it off and then dance around to find the correct light angle where I will be able to read the oil level. Redip, go to that "correct" position and read the level.
   / If you struggle to see the hydraulic oil level... #5
A lot of tractors (my Mahindra, for example) have fluid level windows, and if the fluid is new and very clear it's impossible to see if it's overfilled or underfilled, unless the bubble is right at window level.
   / If you struggle to see the hydraulic oil level... #6
wet dipstick = Good dry dipstick = Bad
doesn't get much harder than that
   / If you struggle to see the hydraulic oil level... #7
Many of us don't have dipsticks...the new "way" is sight glass only....it's a PITA....especially if you have a backhoe attached....
   / If you struggle to see the hydraulic oil level... #8
I guess that's another reason I don't need a new tractor. I did not know they did away with dip sticks
   / If you struggle to see the hydraulic oil level... #9
Unfortunately they didn't. There are a lot of them in Friendly Politics :)
   / If you struggle to see the hydraulic oil level... #10
My Kioti has a dipstick. My old Kubota had that hateful sightglass. I prefer the dipstick.
2013 Chevrolet Impala Sedan (A44572)
2013 Chevrolet...
2015 WESTERN STAR 4900 SB (A45046)
2015 WESTERN STAR...
CAT IT28 Wheel Loader Bucket (A44391)
CAT IT28 Wheel...
4yd Dumpster (A44571)
Cannon Digital Safe (A44502)
Cannon Digital...
Chopper (A44502)
Chopper (A44502)
