If you struggle to see the hydraulic oil level...
   / If you struggle to see the hydraulic oil level... #12
   / If you struggle to see the hydraulic oil level... #13
I for one like the sight glass. Lets me quickly check the level without messing with the fill cap. In my case, it's under the seat. If you have a small tractor, you can probably get by with using only half the dye in the container. I just used half for the last change on my JD2320 and have the other half left for the next change.
   / If you struggle to see the hydraulic oil level... #14
I used the JD dye;just make sure to tell your Kubota dealer,mine thought I had put ATF in it.Well worth the couple bucks it cost.
   / If you struggle to see the hydraulic oil level... #15
I pull the dipstick, wipe it off and then dance around to find the correct light angle where I will be able to read the oil level. Redip, go to that "correct" position and read the level.
If you heat the end of the dipstick red and plunge it into water it'll stay black and make the oil easier to read..........M
   / If you struggle to see the hydraulic oil level... #17
I have a sight glass and I like it. I can check the oil level as I'm walking by. I can understand that it would be a pain with a backhoe attached.
   / If you struggle to see the hydraulic oil level... #18
My John Deere Z820 A Zero Turn has sight glasses on the wheel motors but, you have to stand on your head with a flashlight to see them.
   / If you struggle to see the hydraulic oil level... #19
I dumped some of that JD red dye into the hydraulic fluid on my Kubota L3200. The crystal clear Super UDT2 & sight glass were a poor combo. You couldn't tell if it was overfilled or underfilled. Heck, you could barely see the line when it was in the middle of the site glass. Need to get some more for my new L4060. It has a dipstick instead of sight glass, but its still a challenge.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A51692)
2004 Pierce Tilt...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
