If you were selling, how much
   / If you were selling, how much
fixed...means frame was cracked and repaired by certified/welder shop. I have pics to show buyer, not going to hide anything. I have put lots of miles and loads on the repair.
true 6 lug and brakes on both axles and spare . needs nothing i would not hesitate to load up and go on 1000 mile trip. my bottom dollar will be 1500.00, going to ask more though....;)
   / If you were selling, how much #13
I think $1500 is a fair price. $1800 is what I would ask.
Chris
   / If you were selling, how much #14
used trailers don't hold a lot of value compared to lots full of new units for 2-3K with all kinds of extras and no use.
I agree with Diamondpilot on the value, maybe a little less since it has been broken and repaired.
   / If you were selling, how much #15
Do work to a trailer and you get married to it quick. New ones are too cheap for trying to get your money out of an old one. I think your bottom dollar at 1500 isn't too bad.
   / If you were selling, how much #16
Just for reference - Bought a new 16' with a 2' drop (18' total) with rear ramps (slide side to side on a 1" steel bar type), 4 wheel brakes, 12K rated, No spare with it at tiem of purchase, out the door here in WV for $2200 2 years ago.
Good luck with your sale
Thats a good deal. A new 20' trailer 10 k capacity trailer are priced anywhere from 3200 to 3600. Atleast thats what I have found so far, but trailers in my area are not cheap.
   / If you were selling, how much #18
The real question I would ask, as a buyer, is how did the frame get cracked?
The frame cracked right where the full wrap tongue stops.
The reason: I did not block the back of my trailer up when loading/unloading tractor, i did not use the ramps either. I would drive tractor to trailer, put in low and roll up on back up trailer, trailer would lower to ground(back of pickup would raise) and I would drive up on trailer. Same thing when unloading tractor. THe stress of having the trailer back end sitting on ground and pickup rear end raised---thats what cracked my frame. The frame cracked at the transition point where the the full wrap tongue stops and goes to the single frame width,,,right in front of the front axle. I added the trailer drop leg jacks and receiver tubes at rear to keep the trailer rear from hitting ground when loading tractor and use the ramps now.
   / If you were selling, how much #20
Roger that:thumbsup:
I bought my 18 foot dovetail 7k trailer used.
The guy that did own it was a contractor who bought the trailer new and used the trailer for just hauling around two LARGE joboxes and two L-shape fuel tanks, one tank 78 gallon with a nice hand pump and a 110 gallon tank with a new looking electric pump.
When I was able to meet up with the fella after work and go look at the trailer, all and all the trailer had some miles but was O.K. One fender had slight damage, one tire starting was bulging and the rest worn thin, deck was good AND he still had all the fix'ins described earlier all nice and bolted down to it.
"2 grand.... I drag it off with all the decorations bolted to it" I said, there was a slight pause then "Sounds good to me!" was his answer.
I sold the joboxes and the fuel tanks, bought new tires with the proceeds and hammered the fender back straight and ended up with a nice used trailer for under 1400 clams.
I was gunna pass if the package deal wasn't going to work. Don't take much fix'n to a used trailer and one is quick at the price of a new trailer.
2007 JLG 450AJ SERIES II SKYPOWER BOOM LIFT (A52709)
2007 JLG 450AJ...
2023 CATERPILLAR 308 CR EXCAVATOR (A52709)
2023 CATERPILLAR...
2015 DRAGON  130BBL VACUUM TRAILER (A58214)
2015 DRAGON...
2022 BOBCAT T740 SKID STEER (A52709)
2022 BOBCAT T740...
JOHN DEERE DISC MOWER (A58374)
JOHN DEERE DISC...
2016 Ford F-150 Pickup Truck 4x4 (A56858)
2016 Ford F-150...
