Ignorant electrical problem
   / Ignorant electrical problem #11
Tried that. The tractor could be idling for minutes and all of the sudden start clicking and shut off..
Were you ever able to get this issue resolved? What was found to be the problem. I've still got a similar issue going on with mine (L3830 HST) and have replaced the Engine Stop Selinoid and the Ignition switch but still shutting down.
   / Ignorant electrical problem #12
Has your father ever replaced the fuel filter? Fuel blockages can cause exactly the same symptoms... engine cuts out unexpectedly.
After that, some safety switch failure or related wiring issue is probably the next most likely culprit.
It ended up being a glow plug timer and some other solenoid.
LONG 12' FIELD CULTIVATORS (A51243)
LONG 12' FIELD...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
Wolverine Mini Skid Steer Grapple (A50515)
Wolverine Mini...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
2022 30ft 20k Blazer Deck-Over Trailer (A52128)
2022 30ft 20k...
