IH B414 Lugs & dies under a load
   / IH B414 Lugs & dies under a load #1
49tandc
N. Central Fla
SAME Argon 50/FEL; IH B414
I have a '67 B414 that has ran well in the past. I hadn't used it in 6 mos or so. I started it and warmed it up. Idled fine, but when I put a load on it (had discs on it), the engine lugged and died Any ideas where to look.
thanks,
49T&C
   / IH B414 Lugs & dies under a load #2
diesel or gas? either one I'd suspect stale fuel plugged up the fuel filter(s).
   / IH B414 Lugs & dies under a load #3
Yep, sounds like a fuel supply problem, maybe if it sat with less than full fuel tanks water condensed and you could have a waterlogged filter now. Trying draining and flushing filters, check air filter for bird/rats nest and report back.
   / IH B414 Lugs & dies under a load #4
It might be as simple as the gas in it went bad.
Ben
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
2017 SANY SY365C LC EXCAVATOR (A51246)
2017 SANY SY365C...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
