IH B414 Lugs & dies under a load
   / IH B414 Lugs & dies under a load #1
49tandc
N. Central Fla
SAME Argon 50/FEL; IH B414
I have a '67 B414 that has ran well in the past. I hadn't used it in 6 mos or so. I started it and warmed it up. Idled fine, but when I put a load on it (had discs on it), the engine lugged and died Any ideas where to look.
thanks,
49T&C
   / IH B414 Lugs & dies under a load #2
diesel or gas? either one I'd suspect stale fuel plugged up the fuel filter(s).
   / IH B414 Lugs & dies under a load #3
Yep, sounds like a fuel supply problem, maybe if it sat with less than full fuel tanks water condensed and you could have a waterlogged filter now. Trying draining and flushing filters, check air filter for bird/rats nest and report back.
   / IH B414 Lugs & dies under a load #4
It might be as simple as the gas in it went bad.
Ben
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2018 CATERPILLAR 320 LONG REACH EXCAVATOR (A51246)
2018 CATERPILLAR...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
