ih boiling transmission oil
   / ih boiling transmission oil #1
farmer gav
ih 885
Hello I am hoping you chaps can help me with a problem I have with my 1987 case international 885L. I was grass cutting yesterday and noticed oil had come up out of the dipstick tube and running out the bottom of the cab. I checked the oil level and it appears a lot of oil has been lost.
I checked that none of the spools were in constant pump and will change the filter before I use it again. Is there any thing else I should look at or an obvious reason why this has happened?
The oil is not hytrans - been like that since I got it last year and I know its always been dealer serviced previously. I plan to change to hytrans with a new filter - can I just drain the oil and put the hytrans in or does the system need some kind of flushing?
Thanks in advance. Gavin
   / ih boiling transmission oil #2
Maybe your 3pt lever is in the raised position and constantly relieving the fluid through the relief valve.
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2015 MACK CHU613 DAYCAB (A53843)
2015 MACK CHU613...
