ih boiling transmission oil
   / ih boiling transmission oil #1
farmer gav
ih 885
Hello I am hoping you chaps can help me with a problem I have with my 1987 case international 885L. I was grass cutting yesterday and noticed oil had come up out of the dipstick tube and running out the bottom of the cab. I checked the oil level and it appears a lot of oil has been lost.
I checked that none of the spools were in constant pump and will change the filter before I use it again. Is there any thing else I should look at or an obvious reason why this has happened?
The oil is not hytrans - been like that since I got it last year and I know its always been dealer serviced previously. I plan to change to hytrans with a new filter - can I just drain the oil and put the hytrans in or does the system need some kind of flushing?
Thanks in advance. Gavin
   / ih boiling transmission oil #2
Maybe your 3pt lever is in the raised position and constantly relieving the fluid through the relief valve.
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2023 Kubota L6060HST Compact Utility Tractor (A56435)
2023 Kubota...
BUYERS PREMIUM & PAYMENT TERMS (A58018)
BUYERS PREMIUM &...
LINDE H80D FORKLIFT (A58216)
LINDE H80D...
