IH Farmal Super C Battery ???
   / IH Farmal Super C Battery ??? #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
I need to replace the 6 volt battery. I did it about 5 years ago and it was an extreme task because I had to remove the fuel tank and most of fuel lines to the carb.
???Is there a short cut to get the battery out of the battery box..
   / IH Farmal Super C Battery ??? #2
On the right side, disconnect the starter linkage at the starter end, pull back towards the seat,out of the way. Disconnect the hydraulic linkage by removing the pin in the yoke at the control lever end, and swing it up, and tie it off out of the way. Remove side panel from the battery box, and it will slide right out.
TANK MANIFOLD (A58216)
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58216)
HYDRAULIC TILTING...
15ft Aluma Craft John Boat with Trailer (A57453)
15ft Aluma Craft...
