IH truck with DT360 engine does it have enough power?
   / IH truck with DT360 engine does it have enough power? #11
So you'd rather have a L10 270HP/850tq, or an 8.2L 230/495 than a DT530 330/1050 because the DT is smaller?
   / IH truck with DT360 engine does it have enough power? #12
I'd rather have a 3406E with 500 hp and 1900ftlbs of torque but I think it would snap the front axle in my little 4700 as well as twist the frame and blow the rear end out. What I'm saying is I want the most torque possible in the largest displacement motor and that USUALLY means a higher hp motor. This may not always be in the cards but I'm going to try and find it.
I'm also saying that dt530>dt466>vt365 or dt360 in the smaller international trucks. What I'm not saying and I think you are implying is that the any of those motors are incapable of being able to do work. The amount of those motors out there with hundreds of thousands of miles out there have proven them to be more reliable than any of the powerstrokes or duramaxes. Will a dt360 engine move a truck down the road and carry a load. It sure will. Will it hold a candle to a dt530E motor with 30% more displacement, 30% more power and almost double the torque in the exact same setup/load. Not a chance.
2019 Bobcat E32i Mini Excavator (A55851)
2019 Bobcat E32i...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2011 CATERPILLAR D7E HI-TRACK CRAWLER DOZER (A52707)
2011 CATERPILLAR...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
