well try as I might to make things better, I give up. As you know by some of my posts I've had a few problems with this tractor the last problem was just a mechanical failure I wasn't too upset about that. I've owned the tractor just over a year and a few months now it's got major problems , I been trying to explain to my dealer that the tractor's transmission housing and three-point hitch arms are alarmingly hot I was told this is normal within the last two months my loader has been moving slower and slower. My dealer sent me home with a thermal heat gun to measure some temperatures I post them they were around 193ーF and out at the axle 157 or 178 and some were even slightly higher than 193 in 200 range. Well new Holland contacted my dealer after seeing the pictures and requested that they physically measure my tractor as though I were lying to verify these temperatures, that's what were going to do this morning, I know they'll get the same temperature results two hours mowing and she'll be hot enough to burn your skin if you touch any part of the transmission housing. The reason I want a lawyer my brother made some good points the seals around all the major transmission housing are all falling out and now the PTO seal is leaking my brother told me basically you have fried the entire transmission housing it's just a matter of time and all of the seals will start leaking not to mention the damage to the axle bearings from the excessive heat. My dealer concurred with this observation my brother made so now what to do, I'm going to make new Holland three offers 1 give me back my sizable down payment and I will call my year of payments a loss I will hand the tractor back to them 2 replaced the entire transmission, or rebuild it from the ground up new seals axle bearings and all of the parts including my hydraulic pump and extend my warranty 3 replace the tractor with the same model and will try again. I think if you look back at my post you'll see a long problem from day one delivery of a undrivable clutch a crack in my brand-new cab roof and six months of trying to feather the clutch when it was just the cab mounts needed to be replaced and now this big problem . I'm really upset at this point not only did I finally get the tractor the way I wanted, it really is the perfect size for what I need to do maintain the property around my house but also take care of the fieldwork, I've looked at a John Deere for second tractor the 5093 limited but it's just too big to drive around the house and barn area. No other manufacturer actually makes a unit this size there either a step smaller or a step too big I hope they hand me a new unit , or replace the entire transmission housing new, no offense to any dealer but I don't think they have a clean enough area to rebuild an entire transmission housing like a factory does were talking about something that should last 40 years with regular maintenance oh well I'll let you know what happens today the rep apparently is coming in to talk to me at around noon time wish me luck.
