Imatch adjustable upper hook
   / Imatch adjustable upper hook #11
It is certainly possible that some might be setup for less than 15 inches bu the vast majority of equipment is set up for 18 inches vertical height on category 1 implements. If you measure from the bottom of the hooks on the lower quick hitch to the bottom of the top hook it should measure 15 3/32 inches. You can lay a straight edge in the lower hooks and measure this easily enough. The extra 3/32" is the difference between the pin diameters but this still works out to 15 inches center to center.
I have some older implement that were made probably before a quick hitch was thought of but they still work.
If I have an implement that doesn't fit the quick hitch I make it so. I am not about to go through getting off the tractor all the time and adjusting the hook up and down.
Me neither, that defeats the purpose of a QH.
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
NEW Fork Extensions (A53002)
NEW Fork...
Ingersoll Rand TS5 80 Gallon Air Compressor (A51573)
Ingersoll Rand TS5...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2025 New/Unused Wolverine Mini Ripper (A51573)
2025 New/Unused...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
