iMatch Bushings / Sleeves?
   / iMatch Bushings / Sleeves? #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
There is currently a discussion in another thread (http://www.tractorbynet.com/forums/showthread.php?p=936942#post936942) regarding the differences between bushings and sleeves when used on the 3-point pins - specifically where i-Matches connect to them. I am looking to understand the differences between them and what is the best applicable use for each. For example, on my MX6 I use a sleeve around the left/right pins so the i-Match connects securely when you pull the latches (and there is a sleeve on the top so the top catch connects nicely). On my Buhler Farm King mower, I tried to use the sleeves and they were too small - so I'm looking to put larger (wider) ones on the bottom pins and a sleeve on the top. However - in this other thread, someone mentioned there were differences and therefore I'm trying to figure out what the difference is so I buy the right ones in the next week.
Can anyone elaborate? Thanks for your help!
-Bob
   / iMatch Bushings / Sleeves? #2
Basically,
Option #1
Pic of LVU12858 from JDParts.
Dimensions of A, B, C in pic:
A: .892"
B: 1.435"
C: 1.26"
Option #2
Also, see:
http://www.tractorbynet.com/forums/showthread.php?t=80502
http://www.tractorbynet.com/forums/showthread.php?t=79162
I think I like the kit better - frustrating that it works out this way and if you have mulitple attachments that you want to secure that you might need more than one kit....
oh well. :(
Thanks for your help and links!
-Bob
   / iMatch Bushings / Sleeves? #4
oh well. :(
-Bob
So I have found that if the implement is left outside the JD bushings rust and the TSC/F&F brand bushings do not. FYI.
Unless others disagree, I think I will buy the JD kit and then buy extra sets of the sleeves/bushing from Fleet Farm/TSC to match. That way I've got a master set to work from when buying the others.
How much is the JD kit?
-Bob
   / iMatch Bushings / Sleeves? #6
I paid $35 for the kit -- BW15056. However, while at the dealer, it occurred to me that I might want to pull the bushing off (neighbor wants to borrow attachment, etc.). Should have some spare pins. The pins are rolled steel and they'll likely expand, distort when pounded out. Dealer can't find part reference. Considered ordering 3 more kits.
Nah, I'll try the JDParts website. Found a slightly different bushing -- PM03015. Cost $4.50 including shipping (includes a pin). Won't likely rust like the kit unit. Only problem; need the tapered sleeve (one with hole in pics), too. Also found a couple of different iMatch sleeves that fit the top-link (Cat I) and the "closed-in" lower 3pt. links that are on a box-blade and a roto-tiller. They were significantly cheaper than the kit bushings as well. PM000353 is one of the bushings that I ordered and it cost $1.00 or $.50.
But, I need to get back to the dealer (or try the website) and get the tapered bushing. Oh well, no rush on the iMatch stuff just yet. I'm still using the backhoe and won't be blading or tilling for a spell... AKfish
Since there seems to be so many options, sources, etc. - I believe I'm going to go with using the standard Deere kit first and then pick some additional parts (Speeco at Fleet Farm or TSC) afterwards.
   / iMatch Bushings / Sleeves? #9
The rust comments are accurate. A thin coat of grease seems to stop the rust.
2018 JOHN DEERE 35G EXCAVATOR (A60429)
2018 JOHN DEERE...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
