Implement HP
/ Implement HP #1
ahoude
Yale Michigan
nothing yet
Is there any rule of thumb out there about how many HP needed to pull a given implement? I have 18" to 24" topsoil with yellow clay under it. My father in law has a 45 Hp Kioti and I has 3 bottom plow, 6' cultivator, and 6' disc. The plow maxed out the tractor but was wondering if a bigger cultivator and disc would be possible.
/ Implement HP #2
45 hp will EASILY handle a bigger disc. In most conditions, incuding plowed ground, that's enough power to handle an 8' disc. As a generality, most tractors can handle a cultivator the same size or slightly bigger than what disc it'll pull. That depends on depth and number of and style of points/sweeps. 45 hp is marginal power for a 3-bottom plow in MOST conditions. And, power is only PART of the equasion. weight and/or traction factors greatly in the tractors ability to handle tillage tools.
/ Implement HP #3
if your on the boarder for a 3 bottom (which you are)
plowing in virgin sod is hard. turn plowing in already cultivated ground is easier. and having clean rust free, well setup bottoms will lessen the HP required.
2020 FREIGHTLINER M2 4X2 S/A 26FT CDL REQUIRED CURTAINSIDE BOX TRUCK (A67148)
2020 FREIGHTLINER...
JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A64553)
JMR 78in Dual...
2002 CATERPILLAR D3GXL CRAWLER DOZER (A65053)
2002 CATERPILLAR...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
