Implement limitations for NH TC45DA
   / Implement limitations for NH TC45DA #1
elgin4420
Elgin, TX
We are seriously considering buying this model, but I don't see the operator's manual online. We want to get a 6' medium duty RC (Bush Hog, Rhino, or Mohawk Bronco) and we want to know what the MFG's weight limitations are. If anybody has that information, or a link to a manual, we would appreciate it.:D
   / Implement limitations for NH TC45DA #4
Even I, who thinks the TC45 w/cab needs more power at altitude, thinks it has ZERO trouble with a 6' mower.
It could run a 7' without a problem.
Thanks to all,
Your experienced opinions put one's mind at ease.
I appreciate the links, although I did not see a section on limitations... is Kubota the only MFG that has Implement limitations spelled out in their Owners manuals?
Doesn't really matter if all of you guys say "No problem":) I'm good with that.
Thanks and Regards
mike..
   / Implement limitations for NH TC45DA #6
I have a TC45DA and I have a 6' "Woods" standard-duty brushcutter. It weights 702lbs. I have no problem. I do not have a FEL but I have the tires filled with liquid. I run it at 1600-1700 rpm for most stuff. The 7' weights 1000lbs.
   / Implement limitations for NH TC45DA #7
Welcome to tbn neighbor --- I've got a Woods BB600 that they consider a "medium" duty but built like other brands "heavy duty". Granted it's only 5' - but I cut like crazy with it. I wanted the narrow one so it could follow through the trees. I got hung up more than once with an old 8n and cutter that was wider than the tractor. Like the others have said here - your 45 will run a 7 footer no prob.
   / Implement limitations for NH TC45DA #8
I agree with the others... a tc45 should be able to 'kill' a 6' mower behind it.
i used to run a NH 1920.. and it ran a 6' mower decently, and would spin a 5' like a helicopter.
Even that smaller tractor had a lift rating of nearly 2000#.. you should be -way- fine and be able to mow anything you could drive over.. etc. with a hp or two to spare..
soundguy
   / Implement limitations for NH TC45DA #9
I have used 4 different rotary cutters behind my TC-45D. I do Bush Hogging as a side job so here are my experiences.
5 ft Bush Hog RZ-60.
6 ft Bush Hog 286.
7 ft Rhino SE-7
8 ft Kodiak Twin Spindle.
I don't even know the RZ-60 is attached, mostly used for tight work in and out of trees.
The 286 was the best fit. Came out almost even with the tires. Could cut 2 inch stuff all day with no problems. Probably the best mower I ever owned. Wish I had never sold it. Tractor handled it fine with no problems.
The SE-7 is a hoss. Since it's a single spindle it is really Looooooong. Very hard to handle in tight spots. Always had to keep the front end loader installed with bucket to counter balance the weight. Tractor had the HP to turn it with no problems. I never really liked this cutter, it's currently for sale.
The Kodiak is great for wide open fields, never ever get in the trees with it. Repeat never ever get in the trees with it. Since it sticks out over a foot on each side you can easy hit things with it. This is good if you want to get close to a fence. It's bad for barn doors it you not paying attention while backing out. (Don't ask how I know this) It's heavy, but not as bad as the SE-7. I still keep the front end loader installed, but I leave the bucket off. This cutter actually uses less HP than the SE-7. I use this mower 90% of the time. It's a real money maker.
The TC-45D will handle any of these mowers with no problems.
   / Implement limitations for NH TC45DA #10
GATC35 said:
The Kodiak is great for wide open fields, ..... It's bad for barn doors it you not paying attention while backing out. (Don't ask how I know this)
Funny you mention that. I have a 10' howse 3pt mower I use on my ford 5000.. and i park the tractor under a tarp car port. .. well.. the tractor goes under fine.. but the mower clears the poles only by about 3" on each side.. so you have to creep in REAL slow. I have (ahem) on occasion.. not lined it up exactly right.
I'll say one thing.. 2 piecec of angle iron clamped around a bent pole with some hose clamps sure shores it up nicely!
Soundguy
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
2016 Ford Explorer...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
