Implement limitations for NH TC45DA
   / Implement limitations for NH TC45DA
Ha!
I read the stories and replies posted on this site and just start laughing. You guys are great to be so open!!
I'm sure I'll make a bundle of mistakes myself... just hope it doesn't end up costing too much!:eek:
Regards
mike..
   / Implement limitations for NH TC45DA #12
I think that tractor should pull any 6' mower, but there are caveats about 7 footers.
Some medium and heavy duty 7 footers have massive blades, and weigh ~900 Lbs. The tractor would run them, but they would be right on the edge HP and weight-wise. I think heavy, knee-high grass would have to be cut in a very low gear. I think a 6 footer would be a better match, and the TC45 should pull even a real heavy one.
Weight-wise, a 6 foot 700 Lb brush hog is right on the edge unless you have a FEL or front weights. I guess a 900 LB 7 footer might require both.
   / Implement limitations for NH TC45DA #13
Hmm.. I'm hving a hard time seeing a tc45 'struggle' with a 700# mower. My 8n lifts an 800# disc with nothing more than a front bumper for front weight.. and that's an old 1952 gasser with a massive 27 hp engine and 2.85gpm/1700 psi belly hyd pump.. etc..
soundguy
   / Implement limitations for NH TC45DA #14
my BB600 weighs 1,000 # and I have no trouble with it. UNLESS I take the fel off then it gets a little light in the front.
   / Implement limitations for NH TC45DA #15
On my TC40 I am running a BushHog 84T which is a light duty twin spindle and there is absolutly no issues running it with my TC40. I believe it weighs in at 700+ lbs. A fair amount of property I cut is very hilly (15 degree on the meter when going across) and it pull it up without any sign of bogging. I have been cutting with the fel on but the bucket is removed.
   / Implement limitations for NH TC45DA #16
As previously stated I'm running a twin spindle 8 ft Kodiak rotary cutter weighting 1,125 pounds. No problems at all with FEL installed, no bucket.
My old Rhino SE-7 weighted (I believe) 1,037 pounds and it was really unstable. Of course the Rhino being a single spindle was over 3 feet longer than the Kodiak.
   / Implement limitations for NH TC45DA #17
Maybe my TC35 is a little lighter in the front end than a TC45, but my 700# BB72 makes it pop wheelies without the FEL. I think I could pick up a 1000# brush hog, but would have to add front weights.
   / Implement limitations for NH TC45DA #18
soundguy
I totally agree SG, and that's basically what I meant. A 6 foot 700-900 LB cutter is an excellent match for the TC45. It's the 7' 1000+ pounders that would worry me.
@GATC45: That's exactly what I'm talking about. A 7 foot single blade brush hog sticks out a long way back there. I guess a HD 7 footer would be right on the maximum for the TC45.
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
24in excavator tooth bucket (A56436)
24in excavator...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
Towable Diesel Generator (A59228)
Towable Diesel...
