Implement Slip Clutches
   / Implement Slip Clutches #1
sweet farms
Kentucky
FARMALL 1206, FORD 4000
Just a reminder - make sure your slip clutches on your implements are working correctly, before you head to the field this spring. I do some shop work for my neighbors and see lots of damage that could have been prevented. Just something I was thinking about......
Kevin
   / Implement Slip Clutches #2
You said the clutch should be on the implement end? I have seen so many on the pto shaft?
   / Implement Slip Clutches #3
johnyyuma
Are you sure you weren't looking at an "over-running clutch"
slip clutch should be on the implement end.
   / Implement Slip Clutches #4
A slip clutch to protect the implement and drive line is always on the implement end of the shaft. A override clutch used where a tractor does not have "live" PTO is always on the tractor. If a implement has a torque limiter clutch (such as a hay tedder) that type clutch is also on the implement end of the shaft. Ken Sweet
   / Implement Slip Clutches #5
Ken thanks for the reminder. I was wondering, given your long experience how do you free and reset slip clutches? I never have a problem braking loose the clutch plates, I am just never sure I have reset the spring tension properly.
MarkV
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
MISC WRENCHES (A53843)
