Importance of spring on bush hog slip clutch?
   / Importance of spring on bush hog slip clutch? #1
rectifier
Saskatchewan, Canada
Deutz DX160, IH B-275, Z225 zero-turn
Got me a JD bush hog with slip clutch from a neighbour to deal with my willow problem in my pastures. I guess I was stupid. I greased anything I could, changed gear oil, ignored the clutch for some reason and went out brush cutting. Worked great until I hit a rock, and the clang-clang-bang reminded me to check the slip clutch!
Luckily the rock was very shallow, the tractor old and tough, and no damage was done to anything.
The clutch was seized for decades. I freed it up with hammer, screwdriver and copious ATF, but now it is loose and slips too easily - the funny disc spring that goes behind the clutch stack had shattered long ago.
Can I just tighten the nut until the clutch grips enough, or should I be looking for another disc spring? Being green the price is sure to be fairly dear for a new one, and the entire stack has to come apart to install it (the driven discs are still seized to the shaft)
I would like to get going ASAP as the conditions are perfect this time of year to cut willows and leave the pasture grasses untouched.
   / Importance of spring on bush hog slip clutch? #2
Fix it.
   / Importance of spring on bush hog slip clutch? #3
I would just buy a whole new clutch. You might find one at Tractor Supply
   / Importance of spring on bush hog slip clutch? #4
Get a new one. The copious amount of ATF now soaked into the disk didnt do any favors
   / Importance of spring on bush hog slip clutch? #5
I get a laugh out of people who automatically assume that just because it's green it's expensive. I fix farm machinery for my neighbors for a living. Believe me it doesn't matter what color it is, it's expensive. The only way you are going to know for sure is to phone your dealer and ask what the price is. If it's the spring I'm thinking of it will most likely be very reasonable because John Deere uses that spring in a lot of applications.
   / Importance of spring on bush hog slip clutch? #7
Go to Tractor Supply, if they don't have the parts to fix that clutch, they also sell new shafts with new clutches pretty cheap. Trying to just tighten it down without the spring will result in having a non-clutching shaft and something WAY more expensive is going to get broken.
Thanks guys, I'll call the dealer and see if the spring is available for a reasonable price. Unfortunately the mower is so old there is no nameplate, and the remains of the spring are only a couple little shards.
Haven't seen the clutches at our Canadian equivalents to Tractor Supply but maybe I need to look harder. This one looks like it is almost part of the drive shaft for the gearbox, I'm not sure if it can be replaced readily.
I'd always heard that these things needed to be lubricated with plenty of oil to allow them to slip. Is the ATF going to be too slippery? I'm only driving it with 35HP.
   / Importance of spring on bush hog slip clutch? #9
Doesn't matter what you're driving it with 35 or 350HP. When the blades spin up to speed and you hit a solid object if the slip clutch doesn't work as designed the torque is transferred upstream to your tractor PTO- BOOM! Remove the shaft AND clutch and match them up. Post pics of the hog and maybe someone here can identify it.
Pay now to fix it properly, or pay later for possibly BIG $$ to fix a broken PTO/differential drive.....
Your call.
With respect to the low HP I was more referring to erring on the side of too much slip due to excessive oil. Less horsepower should = less chirp when starting it up, right?
As long as the oily old discs grab enough to bring the blade up to speed, I'll be happy. I'd rather run with too much slip, as we have lots of rocks, gopher mounds and funny hummocks out here.
Currently working with the dealer to identify the machine and purchase the spring.
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
(1) 5' X 4' TRAILER TAILGATE (A57192)
(1) 5' X 4'...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
2017 Ford E-450 LP Handicapped Bus (A53422)
2017 Ford E-450 LP...
UNUSED FUTURE 12" HYD MINI AUGER (A57193)
UNUSED FUTURE 12"...
