"IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS"
   / "IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS" #1
Muleskinner
Pioneertown, So CA
2015 KUBOTA B2650ROPS
I purchased my new M7040 last July. Around 150 hours I started to notice my FEL bucket would curl down/bleed down when the tractor was left standing. You could hear the bucket "Creaking" when the tractor was parked.
Also from the day I bought the tractor the warning lights on the lower portion of the dash would not come on when the igntion key was turned to the start position like the manual says they should. (Test mode) In fact, I was unable to find any indicator light for the 4X4, glow plug or low fuel warning.
I took the tractor into the dealer in December to have the issues repaired. The mechanic told me the following; both front bucket cylinders were bad. The nuts that held the seal pistons on the rods backed off causing an internal leak. Kubota has admitted a problem with these cylinders on the FEL's for the M5040, M6040, M7040, M8540 and M9540 to their dealers. Both cylinders were replaced.
The mechanic replaced the entire dash cluster assembly, but that did not repair the warning light problem. The mechanic began talking with Kubota technical support and was told, "Certain early tractors were not wired completely at the factory and the dash warning lights will not work as stated in the owner's manual."
I told him at the very least I wanted the preheat warning light to work. Using Kubota technical support he was able to wire the system to allow the preheat light to work, but none of the other lights work. He told me if enough customers complain Kubota will be forced to design a fix and repair all of the early machines.
While the tractor was at the dealer the mechanic also performed some "Kubota factory fixes" on some other known problem items. The wiring for the PTO was left off from the factory, the seat mount rubber bushings were replaced, and the bolts holding the front axle to the frame were checked for proper torque.
Well my friends, I like Kubota tractors, but this does not bode well for Kubota and does not do much for my peace of mind. I know these problems are minor, but none of them should have occured in the first place. I believe EVERY owner of the new M series with inoperative dash warning lights should complain to Kubota. What say you?
While at the dealer today I noticed the mechanic had a new (25 hours) M5040 2X2 with turf tires split in half. It seems the owner noticed a noise in the engine. The problem was a broken injector pump "camshaft." I asked the mechanic what that was, as I had never heard of an injector pump camshaft. He said it was the internal shaft that operates the injector pump. I looked at the tractor all apart and the engine with no head on it and was glad that was not my tractor!!!!!!
   / "IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS" #2
EGADS!!!!!
You'd think this would be worthy of a recall, I would call the company and complain LOUDLY my displeasure about this!
Glowplug will probably be interested in this. Don't think his new machine would be an earlier version though.
   / "IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS" #3
OK, The "M" series incorporates several new design tweaks based on technology and engineering specifications. problems are problems, and it is not that they crop up in use, but how they are handled.
It seems your dealer is handling it? Thanks for the heads up on the wiring.
-Mike Z. :)
   / "IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS" #4
Thanks Muleskinner, I thought I was crazy! I read the owners manual "on the dash light issues" then tore my M5040 apart to find the problem, had no luck. I'm too really pissed off about the dash lights not working. Do you think there is anything Kubota will do for me? Tractor only has 25 hrs on it. I purchased it at the close of my grading season. It's a nice tractor but I sure wish all the warning lights worked on the dash.
Like my dealer said, "The more people that complain about the dash issue, the more likely Kubota will do something about it." I for one recommend ALL new M series owners take their tractors to the dealer and ask that the FEL bucket curl cylinders be replaced with the new design ones. This is a real problem! Don't wait until one year is up and the FEL is out of warrante. All of the dealers are aware of this problem.
   / "IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS" #6
I just emailed technical support in japan to see what the duck they will do for us.
Also, my mechanic said even though the preheat light does not come on on the dash, the preheat system still works, so there should be no problem with cold starts. I know I never had any problems with cold morning starts.
Let me know what you find out. Like I told the dealer, the only warning light I was really interested in was the preheat light. But at $42,000.00 I would like ALL of the lights to work!
My dealer just bought a new Ford F450 shop truck with a service bed for mobile repairs on tractors. I asked him how he would feel if his dash lights did not work and Ford told him "Some early models don't work." He said "I know. I know. I understand just where you are coming from."
   / "IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS" #9
Minus 10 degree here in Nebraska, I really need the light to work so I'm not cranking on the start switch while the glow plugs are on. And maybe on that long day of grading 3 residentail homes in a row, I might need the low fuel warning light!!!
   / "IMPORTANT INFORMATION FOR ALL NEW M SERIES OWNERS" #10
I just wanted to let you know what I made in the shop the other day.
When I change out from the box scrapper to the soil pulverizor my Top Hydro Cylinder drops down when changing attachments, so to get me by at the end of the summer I just put a bunggie on it to hold it up out of the way, so I could back up and hook up to another attachment. While working at my shop I found a stainless steel rod, I copyed the factory hook, but made it much larger so it would be big enough to hold the cylinder up out of the way. A little heat from the torch bent the rod around an old fence post real nice. After installing the new rod/hook, I slide some air hose line over the rod as to not sratch the paint on the cylinder and to stop vibration. This sure makes changing the top link easier, and it does bounce off while traveling with no attachments on.
2013 ACURA ILX (A50324)
2013 ACURA ILX...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
John Deere 2640A Tractor (A50860)
John Deere 2640A...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2021 Dodge Durango SUV (A48082)
2021 Dodge Durango...
