In a jam, need help!
   / In a jam, need help! #1
lawn_king
Veteran Member
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
My tranny in my 2320 hst is way down and no dealers are open to get udt. Is there oil I can get at tractor supply to get me through one day. Thankx in advance gentlemen!
   / In a jam, need help! #2
Your Owner's Manual will give you Kubota specs for hydraulic fluid for your BX2320.
Walmart, Tractor Supply Company, NAPA and other auto supply stores sell Hydraulic Fluids.
My owner's manual is 50 miles away in my shop. Was hoping to get the info without it. Thank you
   / In a jam, need help! #4
The fluid can will tell you if it is UDT equivalent or not. Most of the half decent fluids are UDT equivalent. Not necessarily true for Super UDT.
   / In a jam, need help! #5
If it still reads something on the stick, I'd leave it alone until Monday. On the other hand, any hydraulic fluid is better than none would be my approach. You could always drain it at your convenience and replace the HST filter.
Thanks guys. Can someone give me the transmission oil capacity? Thanks
   / In a jam, need help! #7
My owners manual state that the B2320 HST capacity is 4.0 gallons....which is the same for the 2920 and 2620 including the filter.
Thank you!!!
Anyone using shell rotella universal tranny fluid?
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
