patrick_g
Elite Member
This is quite interesting info, for both shop and home.
I am assuming that there would be no cooling benefit from radiant floor design. Meaning, in the summer, run the tubes instead of through a solar collector, through a pond or underground.
I have been reading a lot lately that cooling a house is more of a concern to architects than heating (in terms of cost reduction / energy efficiency).
So, what about a more energy efficient cooling? I would think this is just as important as the radiant heat in the winter.
Dehumidification is an important facet of comfort cooling of occupied spaces.
Radiant cooling of a slab (to act as AC) will require temps near or below the dew point which will promote mold if not make puddles on the floor not unlike the outside of an ice tea glass. Carpet or rugs will get squishy wet.
There are radiant cooling approaches that work. Imagine if you will a pipe of a few inches in diameter cut lengthwise in half and mounted near the ceiling with the open (concave) side up. A smaller diameter pipe is mounted more or less concentric to the split pipe. The smaller pipe circulates chilled water (much cooler than the ground or a pond, more likely chilled by a heatpump.) The warmest most humid air in a room without a stirring fan is near the ceiling. This warm humid air is cooled in contact with the smaller pipe and water condenses out on the little pipe and drips into the larger pipe where it drains to wherever (garden, flower beds, ...) This cools the air and dehumidifies.
If you chill a large portion of the spaces envelope, say the entire ceiling, but do not approach too closely to the dew point you can seriously reduce the effective temperature of the radiant environment and people will feel more comfortable. It is most likely a small compressor unit will have to run with a high duty cycle to do some serious dehumidifying using the latter approach. There are some suppliers of capillary tubes designed to be embedded into a plaster ceiling for radiant cooling.
Cool tubes (pipes buried underground) to cool ambient air prior to being introduced into the space can be effective, especially in sufficiently northern lattitudes where deep soil temps are pretty cool. Here is south central Oklahoma our deep dirt temp is about 62.5F and works well with a geothermal heat pump but would not be optimal for cool tube use. Better to use an HRV or an ERV in these parts.
I had an idea for dehumidification coupled with AC to achieve a ductless system for a great room or similar, a wall designed as a sculpture in concert with a metal sculpture above a shallow pool. The chiller unit chills the wall and metal sculpture till they frost over in a beautiful and dramatic effect (especially with proper lighting) then a flash defrost cycle which has chunks of ice falling off the sculpture dramatically into the pool and sliding down the features of the "Cool wall.) Excess water drains from the pool. radiant temps are lowered and there is dehumidification.
Pat
