doc_cottom
schmism said:word has it retired flat bed semi's work well for bridges. Designed to clear span
quite a few pounds
your likely to find them 28-40' ish. Which would mean building out the embankmanets a bit, but should be farily easy if you can figure out how to get the thing there ( i guess it would need to be set by a crane after you torched off the axles.
A flat bed semi-trailer specs are in the area 10,000Lb in any 10ft span, but do not exceed 50,000 pound total. That is some very basic numbers, aluminum trailers would be different. Don't forget, a flatbed semi-trailer is very flexable torsionly, lengthwise they well wind-up like a big spring if you load them heavily near the edges. Their stength is longitual above the main beams. Most flatbeds that are retired would be 40 to 45 ft. long. The 48 ft. is popular today. Also, the wood decking material used on most flatbed trailers will not standup to high per square inch loading. An example, you cannot drive a loaded forklift on the wood decking between the side rails and the main beams, the wheel loading will punch a hole right through.
