Inching control: anyone have it?
   / Inching control: anyone have it? #21
Steiner and Ventrac probably have the easiest quick connect system of anything out there. On my Steiner you just drive up to it lower the front hitch forks down to the level you need and push onto the attachment and lower the locking lever. Hook up the hydro lines if they have them and or connect the belt to drive the unit. It's pretty simple. Even the full size loader they offer is via quick attach and while it's not a one minute job it's probably a five minute one.
Steve
Thanks Steve. My challenge is this needs to be my "big" tractor and I need to pull a disc and a seven foot mower. And run a potato plow. And lift a man cage high in the air. Those units aren't sized to do row crop farming, not enough clearance. But excluding farming, I think they are very cool pieces of equipment, and having spent most of my life in hilly PA on the other end of the state, and scaring myself on hills way too many times with conventional high center of gravity units. I had to do all my hill work with my Gravely riding tractor, which has a very low CG with the engine in the rear and down low.
I like the Kubota low profile model of the M5. But my is it pricey. I have orchards and those big low flotation tires would be easier on the property, yet still have enough guts to pull a ground engaging implement. Just can't row crop cultivate with it because of low clearance and width of tires. And that's what I have the Super A for, cultivating potatoes one row at a time. But I prepare the field with a disc and that takes weight and a lot of traction. I want to go one size larger, not smaller. But yeah, neat tech. I need it super sized...
   / Inching control: anyone have it? #23
I don't have anything with inching control on the rear, but I have an older Iseki TL3200 with 18 speeds, 3 gear shifts. If you put it in low, low with you on the ground, idle speed, you can put it into gear without the clutch as it is moving so slow. I have many times put it into reverse while beside the tractor to back it up. I have also used it to pull an old car, while walking beside it, I can go back to the car and turn the wheel and walk up to steer the tractor. When I said slow, I mean SLOW. High, high and 3rd gear is about 12 mph at top RPM.
   / Inching control: anyone have it? #24
My tractor weighs easily double what a 4066R weighs,, and my tractor has a 3 point that is easier to connect than a tractor equipped with "inching"
Inching does nothing to help if your tractor is at an angle to the implement,,
neither does a quick hitch,
The extendable hitch arms on my 40 year old tractor resolves both,,
Lift the top lever, the arms extend up to 6 inches,, also each side is independent,, so, if the tractor is at an angle, one arm can be extended more.
My flail mower would be almost impossible to connect without the extendable arms,, and I have an "inching" system on the tractor.
For inching,
I can point the front loader bucket down, stab the bucket into the ground, and by rocking the bucket slightly, the tractor will inch back or forward,
The extendable arms also help when it is time to disconnect the 3 point attachment.
By lifting the lever, if there is "back force" on the lift arm pin, the force can be removed.
Sometimes a small crowbar is needed to lift the latch if the force is great enough.
Still, the crowbar is better than hammering the pin out of the lift arm when disconnecting,,, :thumbsup:
   / Inching control: anyone have it? #25
Advantage to having an older model where the inching feature is just tapping the reverse HST pedal while standing beside. No seat switch.
I can do this with my BX (standing up) to inch to connect FEL Q/A implements. Tapping it won't kill it... doing more than that, will!
   / Inching control: anyone have it? #27
Its like I said - attaching 3-point implements is difficult and can become dangerous. Thirty six years and my only problems with my hands is age. The ONLY time I ever got hurt with the 3-point - I had a second person helping. I was hunched down and he lowered one of the lower arms down on my knee. It was only a bruise but shocked the crap out of me.
My claim to fame on this implement attachment situation - - I may be slow but I still have all my parts and they work pretty well.
   / Inching control: anyone have it? #28
That old International 584 was WAY ahead of its time! Not only on the 3 pt arms but 4WD to boot. Very nice :thumbsup: I wish I had one.
   / Inching control: anyone have it? #29
...................Inching does nothing to help if your tractor is at an angle to the implement,..................:
Being able to move the tractor slightly has helped me connect implements that weren't lined up exactly right. If I get the first arm on the draw pin and move the tractor slightly it rotates the implement to enable me to get the second draw pin hooked up.
   / Inching control: anyone have it? #30
I believe you can get tractor with HST in the size you are discussing. We have a B2710 kubota and I used the hst pedals to help line up the lift levers often but I do put it in low range. At idle basically a creep. If you get good extension arms and keep the parts clean and lubed some they work good. Have both Kubota and JD with arms with this built it and it helps a lot. A possible options for hooking up is to use tow implements if an option. No idea the implements you use but there are tow box blades, sprayers, disc, and of course many 3 pth implements can be converted to tow. If you ever use tow implements you will find they have real advantages but do give up some also.
As to the pto shafts, just wondering here. The issue is you need good access and two strong hands to work the latch mechanism as you slide it onto the tractor's pto shaft. Maybe it would be easier to install the shaft onto the tractor first, hook up the implement and then hook up the shaft to the implement end. Realize this will bring other issues like how to keep the drive line in place as you back tractor into place with the implement but you some shafts use a shear bolt on the implement end that should be easier to connect than the tractor end.
No idea how a pto hooks on a skidsteer but is that something that could be converted for tractor use?
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
utv cart Honda (A56857)
utv cart Honda...
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
