seaneastok
- Joined
- Sep 8, 2012
- Messages
- 205
- Location
- Panama,Ok
- Tractor
- 2012 Mahindra 4530 4x4 ML245 FEL. 58 Ford 861D.65 Ford 4000
I used to use a standard 5 gallon Jerry can,(like you would find on an off road jeep)Bought a new one, drilled a hole in it,Brazed a nut up to it and mounted a shut off and hose barb..a few feet of fuel line.hooked to the carb. hung it on the wall and done..I would suggest though to use a low oil shutoff or keep close eye on the oil level .Some smaller generator's will use oil and risk damage with too long of run times that the larger tank will give you.
Regard's
Sean
Regard's
Sean
