Inderesting rear blade attachment for "gradering"
   / Inderesting rear blade attachment for "gradering" #1
bcp
Super Star Member
SW WA
Kubota BX2360
Found on CL, not mine.
6' Driveway Blade
00C0C_jzt5yIlXFWP_600x450.jpg 01111_cGB4Npcoiyi_600x450.jpg 00S0S_3YtuUzovwCY_600x450.jpg
Bruce
   / Inderesting rear blade attachment for "gradering" #2
Looks like a well built piece of equipment, not sure how much use the arm out the back would be.
   / Inderesting rear blade attachment for "gradering" #3
If that pipe on the end of the boom is a lally column, at that distance it could add a few hundred pounds of downforce on the cutting edge of the blade. it looks to be about twice the distance from the blade as the blade is from the 3 pt hitch pins. That pipe would also act as a gage wheel, lifting the blade if the front wheels rose on a bump, giving a smoother result.
   / Inderesting rear blade attachment for "gradering" #4
I can't tell if the pipe is flexible up and down at the connection to the blade. If it is I think the pipe would act as a final smooth tool and on the last pass lift the blade and drag the pipe. Neat idea, but I wonder if the pipe can easily be removed and if the blade can rotate completely around?
   / Inderesting rear blade attachment for "gradering" #5
I think it might be a "gage wheel" and a smoother all in one. It would certainly keep you from cutting to deep at the start of a hump like Baby Grand says. And it could flatten the berm of dirt comming off the end of the blade.
   / Inderesting rear blade attachment for "gradering" #6
I sure would like to see a closeup of the connection. If the pipe can only go a limited distance down then the top tilt of the blade will dictate weather the pipe will drag or be suspended in the air as weight. If the pipe cannot move up or down at the connection then it would be a "gage wheel".
Seeing that the blade is setting all the way down (and tilted forward) and the pipe is still on the ground it would have to be a drag only, unless a pin can hold the pipe at certain levels.
I can see where an adjustable height pipe would add versatility to the blade as long as the total length was not a factor.
   / Inderesting rear blade attachment for "gradering" #7
one heck of a rear blade there!! would make for one nice "grader"
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2021 Caterpillar 299D3 (A53317)
2021 Caterpillar...
2015 Chevrolet Silverado Pickup Truck (A55315)
2015 Chevrolet...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2016 CATERPILLAR CB34B SMOOTH DBL DRUM ROLLER (A52707)
2016 CATERPILLAR...
2018 Caterpillar 259D (A53317)
2018 Caterpillar...
