indoor spas
   / indoor spas
I want to thank all responders.
I do think that the cover is key in holding down the moist air that the spa will make when in operation.
My idea of skylights may need to be changed to a louver vent in the gable end as snow will be sure to sit on the roof and ice could prevent the skylights from being able to open.
I will be looking for units that are intended to be flush mounted into the floor and have remote filters and pumps and hope that they are less expensive than the free standing wood enclosed ones that you always see in the shows.
I will keep you all posted as to the progress of the project.
Thanks again.
   / indoor spas #12
Make sure that you create a very good vapor barrier between the spa and the rest of the house. Without it, moisture can find its way into the main house and create more problems than you want to deal with.
Also, in central MA, you may want to consider a heat recovery ventilator. Here's a link to an example. If you just exhaust the air outside, you'll lose a lot of heat, which you'll want to retain to keep the spa comfortable.
   / indoor spas #13
</font><font color="blue" class="small">( <font color="blue"> the cover is key in holding down the moist air that the spa will make when in operation </font> )</font>
I think that's the key. An auxillary vent might also help. Ours is an outside spa and I will tell you that a lot of condensation builds up on the underside of the cover but since we don't have to top it up very often, not much of the moisture escapes to the surroundings. In fact, it's probably less than if you were running a humidifier in the home.
   / indoor spas #14
I agree,,,
Keep the cover on
no problems at all
leave uncoverd I've seen them rust eveything metal in the room........
tom
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
2021 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2021 Allmand Bros...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
2014 Jeep Patriot (A53424)
2014 Jeep Patriot...
