injection pump help
   / injection pump help
thank you again, i will keep you updated after i get new parts and installed!
also im sure i will have more questions lol
ok thepumpguysc
could you help me again , i finally was able to work on tractor this weekend, think i got wrong nozzles i noticed before installing little holes in the top were .007" smaller, installed anyway to see as it was getting to much anyway.
now when running it will only idle, full throttle does nothing engine speed wont change at all, so now i assume not enough fuel!
on my original nozzles it says 141 (some symbol here) NP-DNOSD2110
new nozzle just says DNOSD2110 ( but on the bag it came in has an M-DNOSD2110)
do you know where i can get the correct one if this is the problem?
also i think i will eventually have to send fuel pump to someone for rebuild seems to be getting fuel in oil lubricating compartment.
also if anyone here has an allis 5020 and can take a picture of there fuel pump it would be greatly appreciated!!
   / injection pump help #14
Those ARE the correct nozzles.. the M is just an aftermarket company P# symbol.. Because Kiki {Zexel & Nippon Denso/NP} has a copyright on their P#'s, aftermarket companies have to "alter" them slightly.. M=McBee.
They make quality parts so your problem isn't gonna be w/ the "nozzle" itself..
Assembly. maybe.. opening pressure, maybe.. quality of the noz..no..
i'll take back apart, and check i dont think they will go together wrong though, and i did torque them together to 50 ft lbs also
the (141) on the origanl nozzle before the part number doesnt account for anything right?
   / injection pump help #16
No, nothing.. batch # "maybe"?? but nothing from a technical side of view..
just wanted to send out a huge thank you to you thepumpguysc, i got tractor up and running this weekend sounds good, i think i dialed the fuel back also, seems like little less smoke. when it dries out from the rain i'll give it a go and be able to tell better.
thanks again for assistance, info to help me complete it.
if i could ask one more question, when i do need to get fuel pump rebuilt, is there anyone you would know of that works on these oldies?
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
