injection pump problem case 580 c
   / injection pump problem case 580 c #11
Found the problem. The Flex washer had disintegrated and partially filled the pump with what looked like coffee grounds. as soon as I dismantled the pump I saw the problem. In the process of rebuilding the pump..
   / injection pump problem case 580 c #12
I would take a look at the governor weight retainer rings as these have a habit of disintegrating and coming apart. The plastic material isn't up to the task and is usually replaced with a metal retaining ring that doesn't disintegrate. I think you have more happening in your pump than you realize. I think you should try and get a manual for the rebuilding of your pump.
Parts are readily available from US Diesel out of Fort Worth , Texas. I bought parts for the injection pump on my 1969 JD450 from them and was able to rebuild my pump. Parts prices were very reasonable cost wise - certainly for me in Canada where we are used to getting "ripped off".
HTH
CAT 938B 2 Wheel Loader (A47384)
CAT 938B 2 Wheel...
KUBOTA M6800 TRACTOR (A51243)
KUBOTA M6800...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
