Injection pump rebuild? Successively more common stallouts.
   / Injection pump rebuild? Successively more common stallouts. #1
2345joes
Western Oregon
John Deere 820
1973 820. Transfer pump looks rough, but seems to pump well. Cut off solenoid audibly engages with the switch.
   / Injection pump rebuild? Successively more common stallouts. #3
Doesn't mean it's holding. Normally closed is how they work. So it's held open while running. So as it gets weak, more shut offs....
   / Injection pump rebuild? Successively more common stallouts. #4
Also members Tx Jim and/or thepumpguysc may be able to add more specifics to your question regards the '73 2-cyl 820 injection pump.
At the end of the season last year the tractor would run strong for a while, but then loose power and stall out. It restarts right away, but within a few minutes looses power and stalls out again. It seems to run longer if it has been parked, with a shorter run time after every restart.
There was rust scale in the transfer filter and the diesel had a reddish tinge. Fuel tank was replaced. New fuel looks great. Bleed the fuel lines from the tank to the injection pump until no bubbles a section at a time. There is a new return line off the injectors as the tank is a different style than the original.
I have read that breakdown of the plastic inside the injector pump listed as a common problem with the Roosa master pumps.
Is there anything else to consider before sending it out for a rebuild?
Thanks,
Joe
Ps I can work on posting a video link also
   / Injection pump rebuild? Successively more common stallouts. #6
thepumpguysc did a good job on our old FORD pump rebuild. Even sourced some no longer available parts needed.
Tractor is running strong. I recommend you talk to him.
   / Injection pump rebuild? Successively more common stallouts. #7
On top of the pump is a checkball return connector..
Remove it and start the engine.. fuel WILL flow out of the open hole so be prepared for that..
It should stay running..
I’d be happy to have a look at it.. just contact me thru this site.
   / Injection pump rebuild? Successively more common stallouts. #9
Yup.. sounds like a clogged return connector..
Remove it from the pump..
Start it and see if it continues to run.
I’ll give it another try this weekend. If so does this mean time for a rebuild?
UNUSED FUTURE NWS38 NON CONNECTED WOOD SPLITTER (A57193)
UNUSED FUTURE...
Deere 333G (A53317)
Deere 333G (A53317)
2008 Ford Escape XLT SUV (A55853)
2008 Ford Escape...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
UNUSED X-STAR GRAVEL LEVELER QUICK ATTACH (A57192)
UNUSED X-STAR...
2016 Chevrolet Impala Limited Sedan (A55853)
2016 Chevrolet...
