Injector cleaner
   / Injector cleaner #11
Techron has a very good reputation and has been around for quite a few years. It's even available at most places even Costco (4 pk.).
DEWFPO
   / Injector cleaner #12
I've had good luck with Chevron Techron D used twice in the life of our 240D. So, when my gasoline powered generator started giving me troubles, one of the things I did was to put fresh fuel in its tank and run some Chevron Techron (without "D") through the carb. In reusing the old fuel, I add 1 once of it/gallon and put it in the tank of my convertible.
The generator, with fresh fuel and new spark plug and cleaned air cleaner, ran like a top.
I've had very good luck with Sea Foam in carburetored engines. They'll be rough running either at idle or speed. Put some Sea Foam in the tank, and they've all been set right without tearing down the carbs. Done this on essentially all my small engines. Fixed all of them up.
Just felt I needed a heavier duty job on the generator and went with the Techron. Sea Foam might have fixed it, too.
Ralph
   / Injector cleaner #13
On road truck drivers have used K100 products for years. They have it for gas, diesel, marine, and even 4 wheelers. Find it at any good truck stop. It's proven to work. Ask any trucker what they depend on. Trac
   / Injector cleaner #14
I have used the below for a cleaner:
Lucas (overpriced oil in a bottle and will cause issues if over done)
Seafoam (overpriced now and works good).
Amsoil power foam (in non diesels works mint)
Techron (ligher wallet......)
Amsoil PI (works good on engine they need it)
MMO (UCL gas and diesels WELL but not a cleaner)
Schaeffers 131 NEUTRA (works very well)
   / Injector cleaner #15
^^ False informantion....
read post #7 Gumout Regane IS Techron same stuff more or less, has PEA and works well.
   / Injector cleaner #16
just saying what my outcome was....Not false bud.
   / Injector cleaner #17
Just clearing the waters for any member or guest reading the post,Techron is a complete system cleaner,cleans from tank to injector nozzle and does more then lightens one's wallet.
   / Injector cleaner #18
there are various techron formulations some may not be as effective, but where is the proof it did not work ? any meaningful test or hard data ? I agree with Daman on this one
2020 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2020 MACK PINNACLE...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
(APPROX 23) 2" X 3" X 162" TUBING (A54756)
(APPROX 23) 2" X...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD-78HF...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
(2) 67" X 50" MAX TRAILER RAMPS (A54756)
(2) 67" X 50" MAX...
