Injector Pump Removal
   / Injector Pump Removal #11
Glad you got your problem fixed! Was it pretty simple to replace the injector pump?
I just replaced the injectors and fuel filter on my father in laws tractor...it cured the "miss". But, there is still no power. I will be replacing the lift pump tomorrow, and as a last resort, the injector pump.
   / Injector Pump Removal #12
I guess having the old glass bowl in the fuel supply line is still an advantage. You would be able to see contaminated fuel and water etc. early on. Might be worth installing if you don't have one.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58374)
KNOW BEFORE YOU...
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
