Injector pump timing
/ Injector pump timing #1
Skipo
Stockton nj
International 186
How do u time an injector pump on a international 186
/ Injector pump timing #2
Did someone pull the pump off and not pump time it? Most injection pumps have a plug you "push" into the pump to lock the pump on TDC. Cummins also have that on the back of the cover or on the flywheel to lock the engine on TDC. Regardless number one cylinder will have to be on TDC to install the pump and on the gear there is prob a dot to revel the timing marks for the front timing gears. But if you don't know which stroke the pump is firing on then..... Could get interesting.
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
1999 John Deere 7810 (A60462)
1999 John Deere...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
CASE 105C (A62177)
CASE 105C (A62177)
