Inspect your new tractor!
   / Inspect your new tractor! #1
Recoveryhill
St. Croix, Virgin Islands
Kubota L3700SU
I took delivery of an L3700, a couple of days ago. After putting the SQ160 mower together and running an hour or so before dark, I was very happy.
In the morning I was so proud of the tall stuff that I'd reduced to mulch, I walked the cut over area. Hard for even me to believe, a silver bit caught my eye. It was a 1/2 (metric) size nut with the silver base facing up. When I picked it up, not only was it painted Kubota Gray but it was a castle nut.
I looked at the tractor (a nut farm) and decided to go have a cup of coffee and email the dealer. Suddenly it hit me. Castle nuts need cotter pins and are placed where loss of the nut cause very bad things. Such applications are always linkages.
Back to the tractor I started with the front end at the tie rods. Left side fine, same castle nut as I found in the mulch with the pin in place. Right side, no nut, stud backed out of the hub boss leaving only 1/4" engagement with the wheel.
I'll leave it to imagination what would have happened had the tie rod separated from the wheel at PTO power, in low range 4WD! Further inspection of the nut had paint fully coating the outside diameter. Since on the other side, the cotter pin was painted, the nut that fell off, with no paint shadow created by a pin indicates that the pin was never placed on the nut, at manufacture.
I'm only 1,200 miles from the closest dealer, by the way, who was most helpful when they received the news. They sent me a .jpg of a cotter pin and asked me if that was the part I needed. :confused2:
Today I spent four hours in various uncomfortable positions checking every Nut, Bolt, Pin, Screw, Nail, Stud, and other mechanical connections looking for Assembler Holidays. None found and my hopes are high.
Silly me thinking that a check of fluids would be sufficient.:laughing:
Crap happens I suppose but it pays to check!
   / Inspect your new tractor! #2
I purchased my used B21 from the dealer about a month ago. Part of the deal was he would change all the fluids and filters, lubricate it and check it over in general. After delivery I used it for a couple of hours, getting used to it, moving some dirt and rocks. My next order of business was to go over some of the rusty spots with a wire brush, touch up painting here and there, that sort of thing. When I went to wire brush the wheel lugs, all of the lugs on one front wheel were loose, some of them were half way off the threads. Trust no one but yourself.
   / Inspect your new tractor! #3
Lucky you saw the nut, wonder what the odds on that are? Time for a run to the casino!!
Rick
   / Inspect your new tractor! #4
So far I have had three Kubotas delivered to my house and only one, the RTV900, immediately returned to the dealer the same day it arrived due to issues. My units are also from two different dealers! Loose bolts has been the largest issue and leaks a close second. I have also noticed that they haven't been careful when filling the unit with fluids. I have found a few leaks that I traced back to overflow or the dealer simply missing the fill hole. The dealers have always taken care of the problem and the latest put some freebies on my unit when I sent it back, but if they would just take a little more time setting it up it would save them and me aggrevation! Wonder if next time they would deliver to me everything crated up and I'll do the setup?!? Might be worth asking....
   / Inspect your new tractor! #5
Just curious -- what was the problem with the RTV 900?
Steve
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
1000000 (A47477)
1000000 (A47477)
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
EZ loader trailer (A56857)
EZ loader trailer...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
