Snow Install 54" blade on 2320
   / Install 54" blade on 2320 #1
Elklakedoug
John Deere 2320
Dealer dropped off the 54" blade for my 2320 - didn't have time to install it, told me it was "simple". Could you give me a few points, as I've yet to do it, and would love some wisdom.;)
   / Install 54" blade on 2320 #2
Do you have the quick hitch already? Or was that dropped off too?
There should be an installation section in the manual, assuming there is a manual.
Both the quick hitch and the blade snap right on, unless the 2320 is different from other sub compacts
   / Install 54" blade on 2320 #3
it should be 3 pieces for the blade, not counting the front
attaching support plates (they bolt to the front side frame
of the tractor)
there's a box type part that pins into the above mentioned
front support kit.
then the front hitch pins onto that,
and the blade goes on the hitch, all with
quick pull pins and no tools (except for the
front support kit)
hydraulic lines hook up where loader couplers are,
color coded (although a running change may leave you
with reb/blue on tractor and not the blade)
if everything is in boxes, that's another story,
you will have to assemble the hitch with the cylinders.
thanks! appreciate it - had our first snow last nite....
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
