installin gpoints for a 420 Graden tractor
   / installin gpoints for a 420 Graden tractor #1
rickvs
Need help installing The points on my 420 John Deere garden tractor
   / installin gpoints for a 420 Graden tractor #2
What is it that you need to know, the point gap?
yes, is it Top dead center or BDC
   / installin gpoints for a 420 Graden tractor #4
when setting points (on anything) i jog the engine (or entire vehicle if easier) so that the points are open at the highest point on any lobe on the distributor. set the point gap with the correct feeler gauge and adjust as required (generally a turn of a screw). you want to set the gap when the points are breaking on the highest spot on the distributor lobe.
top dead center / before top dead center only applies when setting engine timing, and not point gap. i'm not the least bit familiar with that tractor, but you should be able to find that information all over the internet. if not, call any deer dealer and the service or parts desk can probably tell you. i did, however, recently replace the points and set the timing on a 1950's john deere 420 crawler tractor, though that's a different animal.
Rock Rake Rail w/ Tines (A49251)
Rock Rake Rail w/...
2021 Ford Explorer SUV (A48082)
2021 Ford Explorer...
2004 Dodge Ram 3500 4x4 Crew Cab Pickup Truck (A46684)
2004 Dodge Ram...
Fork Lift Block & Brick Forks (set of 4) (A49251)
Fork Lift Block &...
Howard Rotovator (A49251)
Howard Rotovator...
2024 OTHI Mini Excavator (A46683)
2024 OTHI Mini...
