Installing D-Rings Bolt on vs Welded
   / Installing D-Rings Bolt on vs Welded #1
p0peye
southern tier Ny
JD 2520
I have a PJ Utility trailer duel axle rated 7000lb 14ft with 2ft dove tail total 16ft it is the U8 model with 4 ft removal side rail at the front to load sideways. Well the rails are all bolted into the stake pockets with 3/8 " bolts from the bottom. I have to leave the rail in because the rear load ramp is attached to the side rail when up. There are only 2 extra open stake pockets at the rear of the trailer 1 on each side. So I want to install 2 to 4 D-Rings toward the front 2 on each side. I have bolt on d-rings rated for 11000lbs and would use 3/8" grade 8 course thread as near as I can tell these would be rated for 10000lbs would these be strong enough to tie down my JD2520 w/fel and 655 tiller. I would be using 5/16 g 70 chain
and tighten them with ratchet load binder. Also the d-ring would have to be bolted on sideways making the stress on one side of the ring. I hope I have made my question clear. I could use the weld on d-rings but I would have to find someone to do the welding so would the bolt on ones be strong enough .
   / Installing D-Rings Bolt on vs Welded #2
I think it should be fine. I would bolt them on and that way if they do not work out you can do something different or stronger.
Chris
   / Installing D-Rings Bolt on vs Welded #3
I did something similar for my 2004 Isuzu NPR stakebed (8x14 ft bed). I need to use the stake pockets for the side fences, so I got some of those 12,000 lb rated D-rings, some 1/2" steel angle, 1/2" grade 8 hex bolts. Used 6011 root pass and 7018 cap pass to weld the D-ring retainer to the angle.
   / Installing D-Rings Bolt on vs Welded #4
I installed 4 of the 11k D rings down each side of my 10k trailer. I drilled the 3/8 inch square holes out to 1/2" diameter with a core drill and used grade 8 bolts with lock washers and nuts drilled through the main frame rails. If I ever sell the trailer the D rings stay with me.
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52706)
2020 CATERPILLAR...
2023 RAM 3500 4DR 4X4 CAB AND CHASSIS (A56138)
2023 RAM 3500 4DR...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
Case Titan 3530 (A55302)
Case Titan 3530...
