Installing my grapple on my B7800 today
   / Installing my grapple on my B7800 today
I am picking up some quick couplers this morning. I will finish the installation over the weekend. The grapple is easy to remove so the wt of it is not a big concern for many of the other functions I use my tractor for. Most of the time it will not be on the loader and I use it as a fork lift more than anything.
That is a nice idea Gordon, I have been thinking of how I wanted to do just that with the Grapple jaw
Well I went and took my lines down to the hydraulic shop and had the lines cut and new quick release fittings set up on the lines. I will finish the install today and everything should be up and running. I have some more welding to do around the grapple hinge tube and I also want to tack in the backing plates on the inside of the bucket. I should add some hooks too while I have the welder out.
   / Installing my grapple on my B7800 today #13
Nice job, I'm thinking of getting a grapple also and was wondering if the one centered in the bucket works good for you.. I looked at the double ones also
Is there a need for two?? Also has anyone got a price on the One Touch system, mine will be going on a B2630 Kubota
We I just finished getting everything working. I was having a problem with my quick connects. The were restricting the flow of hydraulic fluid and it took me a bit to figure it out. I wound up eliminating them and It works great now. I went and changed all the fluids and then pulled a couple of stumps up. I have some more welding to do tonight and I will be good. I will continue with my pond tomorrow
Well I just finished the last of the welding and did a jiffy paint job to keep it clean
WR Long Diverter
Power beyond line
New loader control switch to operate Grapple
   / Installing my grapple on my B7800 today #18
I'm getting ready to order an ANBO bucket grapple and a WRLong valve kit for my B2630..How do like the valve set up and did you have any problems with it..Thanks
I love it, it was very easy to install & WR Long is very quick to answer questions. There is a lot that is very vague and that is why I posted the 3 video's. The installation of the WR Lond diverter is exactly the same.
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
John Deere 3032E with loader and Box Blade (A55314)
John Deere 3032E...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
Mini John Deere Truck (A55853)
Mini John Deere...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
