Installing RK/TYM third function valve
   / Installing RK/TYM third function valve #1
DonRybak
Central FL
RK37HC
I'm in the initial stages of ordering a grapple for my RK37 and planning on installing a third function valve myself. I plan on purchasing the valve from RK since their kit is complete with all fittings, joy stick, steel lines and hydraulic hoses. Been doing a lot of video watching on YouTube of the valve installation but they were all after market from Summit and so forth. Today I finally found one that is done with the RK kit. It's done on the RK55 but should be the same steps for the RK37. It's a little long but a well done video.
Third function valve install
It's actually simplier process than I thought it would be since everything is cut to the correct lengths.
   / Installing RK/TYM third function valve #2
Keep in mind that the in the video, the guy is installing a diverter valve and not a third function valve, even though he is calling it a third function in the title.
Not sure if you looking for the actual third function or the diverter valve.
ptsg, you're correct that it's actually a diverter valve but that's what RK sells and installs as a third function when ordered from them as an option at tractor purchase or add on at a later date. A lot of the after market valves advertised as third function are also diverters if you dig down into the specifications. From what I have found, actual true third function valves are much costlier than the diverters. For no more than I would use it I think it'd be fine for me.
   / Installing RK/TYM third function valve #4
Oh ok. I just wanted to point that out in case you were expecting a third function valve and the guy is using a diverter valve. The installation is bit different for the third function.
As far as costs go, I don't think there is much difference. Sure the third function will be slightly more expensive due to the extra hoses and fittings needed.
2005 IHI 35N-2 Midi Excavator (A46683)
2005 IHI 35N-2...
2017 Komatsu PC138US-11 Excavator (A42203)
2017 Komatsu...
2012 STAGECOACH TRAILER MONORAIL (A47001)
2012 STAGECOACH...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A48561)
80in HD Tooth...
2003 Mack Vision CX613 (A47307)
2003 Mack Vision...
2015 Ford Transit 150 Cargo Van (A46683)
2015 Ford Transit...
