Paddy
Veteran Member
Bill,
The way these are designed, the only contamination would be at the hydrant. The rubber stopper is either blocking the fresh water flow or the tube drain. Other wise in the on position water would blast out the drain. So as you turn on the water, fresh will flush the tube. So as long as you don't drink the water from the hydrant, I can't see an issue. But you are correct, the bottom of the hydrant tube is filled will ground water. When I have replaced mine in the past, I had to bail the muddy pit. This muddy water is quickly flushed from the tube and I drink from mine all the time. Just not instantly after turning in on!
A flat pad of concrete is a good idea just below the surface. I have ripped one hydrant out as the other poster by catching a loose garden hose with the garden tractor
I do like the 'frost free hydrants" over the convential wall mounted shut offs. I can never remeber to keep disconneting the hose on those dang things and replace them nearly every year.
Patric T
Patric T
