Interesting 4 board gate design / hardware
   / Interesting 4 board gate design / hardware #11
hitekcountry said:
I went out and took a look and it seems I built all the gates that way. Then I tried to think back as to what my rational was at the time I built them. Now I remember I was thinking the brace was a replacement for a turnbuckle and cable. So given that I’ll bet you wouldn’t put a turnbuckle and cable as you describe, from the bottom hinge upward. :)
Diagonal bracing, board or cable, is designed to transfer the hanging load back to hinge stile of a door or gate to prevent sagging. The cable is in tension supporting the hanging load from the bottom and the board brace is in compression supporting the hanging load from the top...so yes they should be opposite of each other.
Kevin
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2008 Caterpillar 262C High Flow XPS Compact Wheel Loader Skid Steer (A52377)
2008 Caterpillar...
