Intermittent starting problem
/ Intermittent starting problem #1
fshafly2
I have a MX5000 with less than 200 hours on it. Twice in the past few months, the tractor unexpectedly quit running when I got out of the seat (pto was off and gears were in neutral). Yesterday when it happened, I had a difficult time getting the tractor started. I shifted gears and back into neutral, lifted the seat and "tweaked" the microswitch lever a few times, and shifted the pto engage/disengage. Eventually, the tractor did start - but not immediately after trying anything. Twice more since I had to play games to get it to start again after I had turned it off. Yet sometimes it starts right away.
Any suggestions on what to do about this?
-fsh
/ Intermittent starting problem #2
-fsh
I think you already have the right idea. It sounds like one of the safety switches is out of adjustment or has an issue. You could try jumpering one switch at a time to see if the issue goes away.
/ Intermittent starting problem #3
-fsh
Fsh, did you ever figure out the problem?
Yes - it was "operator error". I did talk to the dealer's service tech and he told me where to look for the microswitch to the gear shift (I had been tweaking the microswitch to the seat). I was putting the tractor in "neutral" (or more like "out-of-gear"), the shift lever would not necessarily go and rest against the microswitch. Once I saw how it was supposed to work, no more problems.
Easy fix, lol.
-fsh
/ Intermittent starting problem #5
Easy fix, lol.
-fsh
I've been a victim of the same thing a number of times; that's one sensitive little switch. Move the gear shift just a hair from the true neutral position, and it'll trigger the OPC timer relay, which shuts off the fuel pump solenoid... a little while AFTER you get out of the seat, making it that much more difficult to diagnose!
Glad you found the problem.
Josh
Thanks for checking Josh.
-fsh
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2007 CATERPILLAR 304C (A65643)
2007 CATERPILLAR...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2011 BRENNER TANK 200BBL CRUDE TANKER (A65643)
2011 BRENNER TANK...
