International 430 square baler anybody?
   / International 430 square baler anybody? #1
Safarmwv
WV
Landini 5830
Was wondering if there is anybody on here that has an international 430 square baler. I have a question about the twine tension-slack springs on it. Thanks guys!
   / International 430 square baler anybody? #2
Yeah, I got a 430 international square baler. Are you talking the tension spring at the knotter that controls tension in the twine disk or the tensioner springs in the shoot that control twine tension for how tightly packed the bales come out? If your talking up at the knotter start with just slight tension on it. If the twine is not holding keep adjusting(more tension) until the twine disks hold the twine good and snug and run. If the twine pops out, adjust some more until it holds the twine but you don't want excessive tension. If your talking the bale tensioner springs just increase or decrease pressure till you get the bale tightness you want, if you tell me more of your problem more in depth I can help you more.
Rob
Sorry its been so long, been pretty busy. Anyway The springs i was referring to, (there are two) hang off of the frame- the twine comes out of the twine box then threads through these two springs then through the needles. I've had to replace both of them, one is new supposed to be oem about 7" whereas the other is about 18". I don't think this is causing a problem. My new problem is I'm having lots of chaff on one side of the bale, the "cut" side I believe , I am wondering if this is due to a dull knife? If so, what is the easiest way to sharpen or should i replace? The twine is also kind of wanting to push out on one end of the bale, maybe too much hay for the bale length? If so, what is the easiest way to sharpen or should i replace? Also doesn't help that this baler has sat for 2 years- in the weather! Sorry if I am overloading you with stupid questions that may not make any sense. lol! Thanks a million!
   / International 430 square baler anybody? #4
Well the springs your talking about if you got it from Case IH it should be right though both of mine are like your old one, about 18" long. The fraying could be a bad knife, knives are easy to sharpen or cheap if you wish to replace, one screw is all that holds the knife on. First though to get to the knife you need to take off the drive bar that makes the knives cut, this is on the back of the knotters(chute side/rear side of baler) this has two bolts and a spring. Then on the front side of the knotter toward the arm that pulls hay into the plunger remove the bolt that holds the knotter forward, just follow the knotter to the frame. All these bolts use a 5/8" wrench unless they've been replaces with something non original. Once removed pull the knotter back and it will turn up, it will get to a point and not move, pull out on the bill hook tensioner and you will be able to turn the knotter up higher. Now that you can see the bottom you will see the knife and the 1 screw that holds it on, you can sharpen or replace the knife whichever suits you best. As far as the fraying and stuff it depends on what type of fraying and stuff is going on. There are only two things adjustable the bill hook tension and the knotter tension, you will see the bolts with springs on them when you turn the knotter(s) up. If there is fraying going on I would guess one has too much tension, is rusted or too much dirt and debris packed in it making it act as it is adjusted too much. If you go on ebay you can buy a operator's manual that will give you pictures of twine, you find the one that looks most like yours and it will tell you how to adjust. The manuals usually go for around $20 last time I checked. After you adjust it a couple of times and get it tuned right you'll be like man that's so easy, just remember you want just enough tension to make it work, most knotter problems are over tensioning. If you need more help give me a call (517)643-4479 my names Rob. If I don't answer leave a message I farm and don't have any cabs on my tractors and work construction so I don't always hear my phone but I'll get back to you.
   / International 430 square baler anybody? #5
cant get the knives to cut the hole string
2017 Ford Explorer SUV (A55758)
2017 Ford Explorer...
2022 International CV515 Ambulance, VIN # 1HTKSSWK7NH675363 (A54865)
2022 International...
Skid Cropmaster Baler Twine (A50775)
Skid Cropmaster...
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
