International 444 (1968 British model) Power Steering Cylinder
   / International 444 (1968 British model) Power Steering Cylinder #1
jepaul
Calgary
International 444
Hi all,
I need to replace the power steering cylinder for our tractor. The cylinder is one of those with the directional control valve built into it. It hasn't worked for years and basically renders the tractor useless without it. we took it into a hydraulics repair shop and they told us it wasn't repairable. Also, we had a North American wide search for the replacement part (3072695R91) and absolutely nothing came up. I don't have a picture off our tractor but found one of the same unit in another related thread on this site (thanks DickC!):
http://www.tractorbynet.com/forums/...570224-ih-444d-uk-power-steering-dsc02557-jpg
So our only option seems to be to replace it with a similar unit (aftermarket or used) from another make/model of farm equipment, assuming a similar design was used on other equipment of the same era.
Does someone have any ideas for us, either used part # or idea for a retrofit, etc.?
Our location is Southern Alberta, Canada.
Thank you
   / International 444 (1968 British model) Power Steering Cylinder #2
This will be the least expensive option.
Power Steering Conversion Kit for Ford Tractor 4��� 46�� | eBay
But you will need to change your rod ends and brackets etc.
Anadolu makes kits for the style you have shown in the picture, but the cost will be more to get the cylinder.
You must put aside the aspect of dealing with the Turks! ;-)
seal kits seem to be available
Power Steering Cylinder Seal Kit fits Case-IH International 454 574 595 674 684 | eBay
This is ridiculous, but included because :they are out there.
POWER STEERING KITS FOR B-SERIES TRACTORS!
I've spent too much time looking for a power steering retrofit for my Fordson E27n ;-)
Thanks CalG!
I think we'll try the first option. The price seems quite reasonable, even given that some of the items that are included (pump, tank) aren't needed since the tractor has those components already. It's just the cylinder and any components that attach to the tie rod end and tractor frame that we'll need. I think Dad will be thrilled even just knowing that there is a chance that this could work. I'm sure between the two of us we should be able to retrofit it into place. Again, thanks so much for your feedback!
   / International 444 (1968 British model) Power Steering Cylinder #4
Thanks CalG!
For $325 American you can get just the cylinder. It's an ebay listing just like the kit.
but for 20 bucks you get the pump and all the "fittings" that may come in handy for some other project ;-)
I see that hydraulic pump being offered on ebay for $300. That's a bit spendy for a cheap pump, but just shows you might get some of your money back from the kit.
Good to know. Thanks!
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
